When I turn on my A/C, there is no air coming out of the front vent only the back vents are blowing cold air. What is the problem? Please help
Jul 12, 2019 at 3:40 PM
CERTIFIED EXPERT
Welcome to 2CarPros.
Are you getting air via the defroster or on the floor? If you are, it is most likely related to what is called a mode door actuator. This actuator is responsible for air flow direction.
Take a look through these links and let me know if anything seems to mirror what you are experiencing.
Hello and thank you for your help. I also forgot to mention that it was pouring rain yesterday and I turned on the air defogger and it didn't clear the windows either. So, I had to wipe the windows clear and open the windows to let the air in!
Jul 13, 2019 at 7:30 AM
CERTIFIED EXPERT
Welcome back:
Okay, help me understand. The rear could have its own fan system. If you turn the rear off, does the blower motor in the front of the vehicle turn on?
Jul 13, 2019 at 7:20 PM
WENBU69
MEMBER
No, it doesn't. I can control the back from the front in the climate control. I turned on the back A/C today to see if it was working and it was. Still, nothing was coming out of the front vents?
Jul 13, 2019 at 9:14 PM
CERTIFIED EXPERT
Welcome back:
Okay, the first thing we need to check is the fuse which provides power to the blower motor. It is fuse 48 in the junction box on the right side of the dash.
Take a look through the attached pictures to help locate it.
