You should not need to drop the subframe to do this repair. It should just unbolt and then the links are removed and then it slides out. If you drop the subframe not only will you have to do an alignment but you will potentially drop the engine and transmission out on the ground.
According the instructions, you may need to drop the rear of the subframe in order to gain enough space to get it out but you don't take all 6 bolts out.
Let me know if I am misunderstanding something and we can go from there. Thanks
Sep 17, 2019 at 7:18 PM
