When you replaced the struts, was it a complete assembly? Is the noise loud enough for you to record and upload for me to hear?
As far as the subframe, he was referring to the cross member under the engine. See the attached pic. I highlighted where there are bushings that could be bad or loose.
You did check things related to the sway bar, correct? There are bushings on them as well as stabilizer links.
Aug 2, 2021 at 7:30 PM
