I bought this car which has new tires on the rear and really bad ones on the front. When I drove it home the suspension was all over the place. Whenever you hit a bump, it goes to one side, steering is off center, and it pulls to one side. Got new front tires, jacked it up, no play whatsoever on driver side, passenger has a minor play in the ball joint but not enough to cause that. looked at the struts and they appear to have been replaced as the brand is different than the OEM. Noticed that the passenger side strut is not inserted in the way in, inside where it sits. Compared to the driver side which sits all the way in like most struts do. what would a strut that is not sitting all the way in cause as far as symptoms? I am guessing either the driver's side is sitting way too far in, or the passenger is sitting too high to where it should be. it is almost half way in.. I removed the strut bolt and hammered the strut up into the grove all is good, waiting on a new ball joint.
Oct 14, 2022 at 5:08 PM
