Please only answer this if you are 100 percent sure, else I will try a Hyundai Service Center to find out. It is a 2015 Hyundai Accent GLS. A mechanic just installed 2 front quick struts. The suspension does not seem to respond like it should. I am a mechanic myself so I took a look. The strut rod has 2 nuts on it when it is purchased. One on top of the bottom insulator, then the top insulator, then another nut. The top insulator has to come off before installing so the top nut comes off (to take off the top insulator. The strut is installed then the top insulator then the top nut. In all parts diagrams I have seen does not show this second nut. My question is the second nut just a temporary nut so the strut stays compressed when installing (then when the strut is put in car the top nut can come off) or should it stay on? It doesn’t make sense to me why that second nut would be there except a temporary ‘shipping nut’. It is a little tough to describe but if have dealt with one you would know exactly what I am talking about. The attached picture shows that second nut. Thanks.
Jul 29, 2019 at 11:50 AM
