front passenger side hub bearing
1999 GMC SUBURBAN
200,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
JOHNHARVEY
Sounds like a grinding noise almost like bad brakes, but I know it is not the brakes because I just changed them a few months ago, also the tires seem to go bald quickly.
Mar 15, 2016 at 6:06 PM
JOHNNYT73
  • 924 POSTS
Yes, this could possibly be a hub bearing. Place a good floor jack underneath the lower control arm (about where the shock is bolted up). Raise until the tire is off the ground enough so you can get your hand underneath it. Grab the tire from the top and bottom and try to push with one and pull with the other to try and tilt the wheel. if you feel the wheel move when doing this then chances are hub bearing(s) are/is bad.
Here are a couple of helpful links for you to check out. www.2carpros.com/articles/jack-up-and-lift-your-car-safely
www.2carpros.com/.../how-to-replace-a-wheel-bearing-hub
Mar 15, 2016 at 8:04 PM
JOHNHARVEY
Okay, what tools are required for this vehicle?
Mar 16, 2016 at 4:21 AM
