Good morning,
I attached the procedure below for you for the repair.
https://www.2carpros.com/articles/how-to-replace-an-abs-wheel-speed-sensor
Removal and Installation
With the vehicle in NEUTRAL, position it on a hoist. For additional information, refer to Section 100-02 .
Remove the fender splash shield. For additional information, refer to Section 501-02 .
Disconnect the wheel speed sensor electrical connector.
Remove the wheel speed sensor harness bracket-to-body bolt.
To install, tighten to 7 Nm (62 lb-in).
Detach the wheel speed sensor harness from the wheel knuckle bracket.
Remove the wheel speed sensor bolt and the wheel speed sensor.
To install, tighten to 23 Nm (17 lb-ft).
To install, reverse the removal procedure.
Mar 12, 2021 at 5:39 AM
