Front motor mount replacement
2000 TOYOTA AVALON
140,000 MILES • 3.0L • 6 CYL • FWD • AUTOMATIC
ALZACK41
  • 20 POSTS
My car VIN is 471BF28B2YU022042.
If it turns out that this car originally has front motor mount with vacuum fitting,
but you only have available a mount without that vacuum fitting,
then can you still do the replacement?
Another words, can you replace a worn front motor mount with vacuum fitting with a new front mount without vacuum fitting on that car?
Jan 24, 2017 at 12:06 AM
STEVE W.
  • 15,113 POSTS
Should not be an issue. It is likely that the vacuum units were failing a lot so they eliminated that option. Not an uncommon thing.
Jan 24, 2017 at 4:50 AM
