Front motor mount bracket
1995 GEO PRIZM
154,000 MILES • 1.6L • 4 CYL • FWD • AUTOMATIC
OWEN1992
  • 7 POSTS
I changed front motor mount removed the bracket in the process, now there is a worse vibration than before. mount is touching bracket on one side was wondering if it is supposed to and did I put bracket in wrong maybe upside down? there is an arrow on the side of bracket is this supposed to be pointing up or down?
Oct 14, 2017 at 2:40 PM
MHPAUTOS
  • 31,937 POSTS
I am fairly sure arrow should be pointing up, also back off all mounts and drive around the block to allow the engine to settle in to a better position. this can help also remember to tighten all bolts again. let me know how this helps.
Oct 15, 2017 at 4:27 PM
OWEN1992
  • 7 POSTS
Okay, if the mount is touching the bracket on one side if the bracket is upside down could that be the reason it is touching?
Oct 15, 2017 at 4:59 PM
MHPAUTOS
  • 31,937 POSTS
Turn it around and see if it dose not touch anything. can you send a picture? A visual will help.
Oct 15, 2017 at 5:36 PM
OWEN1992
  • 7 POSTS
The mount is one the same way as the old one it is the bracket I am wondering about. I could take pictures tomorrow and post, it is dark and raining right now.
Oct 15, 2017 at 5:44 PM
MHPAUTOS
  • 31,937 POSTS
yes that is fine. i have no access to our data base just now due to a tech problem at the server. so tomorrow i hope to be able to look into things a bit closer.
Oct 15, 2017 at 6:28 PM
OWEN1992
  • 7 POSTS
Okay, thank you.
Oct 15, 2017 at 6:38 PM
OWEN1992
  • 7 POSTS
These are the best I could get.
Oct 16, 2017 at 2:45 PM
MHPAUTOS
  • 31,937 POSTS
is the replacement mount exactly the same size? is the transmission mount okay? The engine looks as if it has shifted side ways onto the mount bracket.
Oct 16, 2017 at 3:13 PM
OWEN1992
  • 7 POSTS
The mount is the same size and the transmission mount looks okay.
Oct 16, 2017 at 3:24 PM
MHPAUTOS
  • 31,937 POSTS
i would just start again, remove mount and make sure nothing looks out of place. i have access to the data base again. i will see if i can find anything relevant.
Oct 16, 2017 at 3:49 PM
OWEN1992
  • 7 POSTS
Okay, I do not have time right now to do it but will as soon as I can. do you think the bolt going through mount would get bent from the engine shift like it appears it did? I hope not.
Oct 16, 2017 at 4:07 PM
MHPAUTOS
  • 31,937 POSTS
i doubt it, it is a fairly substantial attach point. my problem is that it is very hard to visualize this concern, it just looks as if the mount is incorrect, fitted wrong or the engine has shifted due to other mount problems.
Oct 16, 2017 at 6:29 PM
