Here are the directions which include torque specs. I am assuming you are referring to the front. If that isn't correct, let me know. Also, this is for the 3.7L.
The attached pic correlates with the directions.
_________________________________________________________
2013 Lincoln MKS AWD V6-3.7L
Lower Arm
Vehicle Steering and Suspension Suspension Control Arm Service and Repair Removal and Replacement Front Suspension Lower Arm
LOWER ARM
Lower Arm
Removal and Installation
NOTICE: Suspension fasteners are critical parts because they affect performance of vital components and systems and their failure may result in major service expense. New parts must be installed with the same part numbers or equivalent part, if replacement is necessary. Do not use a replacement part of lesser quality or substitute design. Torque values must be used as specified during reassembly to make sure of correct retention of these parts.
NOTICE: The suspension height sensors must be disconnected prior to servicing suspension components. Damage to the suspension height sensors and/or the vehicle dynamic suspension system may occur. The sensors will need to be recalibrated after reassembly.
1. Remove the wheel and tire.
2. If equipped with dynamic suspension, remove and discard the suspension height sensor arm bracket bolt and disconnect the bracket from the lower control arm.
- To install, tighten the new suspension height sensor arm bracket bolt to 30 Nm (22 lb-ft).
pic 1
3. NOTE: Use the hex-holding feature to prevent the stud from turning while removing the nut.
Using a crowfoot wrench, remove and discard the lower ball joint nut.
- To install, tighten to 210 Nm (155 lb-ft).
4. NOTICE: Use care when releasing the lower arm and knuckle into the resting position or damage to the ball joint seal may occur.
Push the lower arm downward until the ball joint is clear of the wheel knuckle.
5. Remove and discard the lower arm forward bolt.
- To install, tighten the new bolt to 185 Nm (136 lb-ft).
6. Remove and discard the lower arm rearward nuts and bolts.
- To install, tighten the new nuts to 99 Nm (73 lb-ft).
- Install the new lower arm rearward bolts from the bottom of the lower arm bushing with the nuts on top.
7. If necessary, remove the lower arm rearward bushing. For additional information, refer to Lower Arm Bushing See: Control Arm Bushing > Removal and Replacement > Lower Arm Bushing.
Installation
NOTICE: The lower arm forward bolt must be tightened with the weight of the vehicle on the wheels and tires or damage to the bushings may occur.
1. To install, reverse the removal procedure.
2. If equipped with dynamic suspension, calibrate the suspension height sensor. Connect the scan tool and carry out the Ride Height Calibration routine. Follow the scan tool directions.
Let me know if this helps.
Aug 15, 2020 at 11:20 PM
