heater not working?
2007 JEEP COMMANDER
150,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
PIPERPUP
  • 10 POSTS
I have hot water going into and out of the front heater core connections at the firewall. Rear heat, on the same plumbing, works fine. I have removed both left and right blend door actuators and manually move the doors to both extremes. Nothing but cold air comes out.
I have not used the heater since the core was replaced two years ago as I was living in Florida. Back in Alaska now and heat would be nice!
At this point I fear I need to remove the dash to see what is wrong. Coolant is full, engine temp is normal, and the blower fan seems to have adequate airflow. I sure would like a simple fix if you have one!
Dec 2, 2019 at 6:51 PM
If you manually moved the blend air doors and no heat comes out, you need to recheck the heater core. Air flow is directed either through or around the heater core. This is done by adjusting the position of the blend-air door. My first suspect would have been the actuators, but you indicated they were checked. That only leaves the heater core. If you could, recheck flow through the front heater core. Confirm the hoses are not just getting warm from the engine compartment. If you are certain there is flow, then something is preventing air flow direction or the blend door from working.
This guide can help confirm the issue
https://www.2carpros.com/articles/car-heater-not-working
I attached a pics below of actuators. Confirm those are the ones you checked. Check out the diagrams (Below). Please let us know what happens.
Dec 2, 2019 at 9:02 PM
PIPERPUP
  • 10 POSTS
Joe,
Those are the two actuators I removed and the blend doors moved freely stop to stop. I also know hot water is flowing through the core. I retired Dodge mechanic told me they had challenges getting adequate water through the front heater core because the straight run past the "t" had less resistance than going through the front core. What he used to do was eliminate the "t". He said to run from the engine outlet to the front core inlet directly. Then from the front core outlet to the rear core inlet. Finally from the rear core outlet back to the return on the engine. I did this and it didn't change anything. I still have rear heat, which means the water has to be passing through the front core as it is plumbed now.
I know it goes against all logic but there it is. I believe it is a parallel type core. If so, is it possible a large portion of it is plugged up but enough open to let water pass to the rear? The rear heat showed 96 degrees today when it was 13 degrees outside.
A little history on the car. The air conditioning died and the problem was traced to a leak in the evaporator coil. They suggested I have them change the heater core while they had the dash apart. I said okay. I have never used the heat after that until a few weeks ago. That was about 2 years back. Another issue from that repair - the AC works great for a while then the airflow slowly warms and dies off until it stops completely. If you shut it off for 5 minutes and start it up again it works for a bit and then dies. Its almost as if the evaporator coil is frosting over, blocking airflow. I hesitate to tell you how many mechanics have tried and failed to fix that one.
Long winded but there you have it. 30 below in a couple more days. Guess I'll be driving my 1983 pickup!
Dec 2, 2019 at 10:38 PM
PIPERPUP
  • 10 POSTS
Joe,
One more question if I may. In your diagram, left side, there is an actuator mode door front. What does that one do? I can see any way to get the hardware off without pulling the dash pad.
Dec 2, 2019 at 10:44 PM
Good Lord! Did you say 30° below? Ugh. You need heat.
Based on how you have it plumed, it has to flow through that core for it to be that hot on the rear. As far as there being a partial plugging in the front core, you would at least get some heat. Now, you moved the doors manually and it made no difference. Something had to have been put together wrong.
Additionally, the mode actuator is what is responsible for air flow direction. It does nothing with temp.
At this point, you have done everything right. However, what is next? Here is what I would do. There is a cover over the heater core and tubes. Remove the cover, confirm the heater core is hot, inspect blend air door function (actually see what is happening), and hopefully, there will be an answer. I'm starting to question if something was put in backwards such as one of the doors. Something is blocking the heat.
Here are directions for removal of heater core. You won't need to complete the entire list. Just go far enough to see what may be happening.
______________________________________
2007 Jeep Truck Commander 4WD V8-5.7L VIN 2
Front Heater Core - Removal
Vehicle Heating and Air Conditioning Heater Core Service and Repair Removal and Replacement Front Heater Core - Removal
FRONT HEATER CORE - REMOVAL
REMOVAL
WARNING: Refer to the applicable warnings and cautions for this system before performing the following operation. Failure to follow the warnings and cautions could result in possible personal injury or death.
WARNING: Disable the airbag system before attempting any steering wheel, steering column, or instrument panel component diagnosis or service. Disconnect and isolate the negative battery (ground) cable, then wait two minutes for the airbag system capacitor to discharge before performing further diagnosis or service. This is the only sure way to disable the airbag system. Failure to take the proper precautions could result in accidental airbag deployment and possible personal injury or death.
NOTE: Take the proper precautions to protect the front face of the instrument panel from cosmetic damage while performing this procedure.
NOTE: LHD model shown in illustrations. RHD model similar.
pic 1
1. Disconnect and isolate the negative battery cable.
2. Drain the engine cooling system.
3. If required, disconnect the heater hoses from the heater core tubes in the engine compartment.
4. Remove the instrument panel.
5. Remove the five screws (1) that secure the heater core and tube cover (2) to the HVAC housing (3).
6. Remove the heater core and tube cover from the HVAC housing.
pic 2
7. If equipped with dual zone heating-A/C, remove the blend door actuator (1) from the passenger side of the HVAC air distribution housing (2).
8. Remove the screw (3) that secure the heater core tubes (4) and retaining bracket (5) to the HVAC housing (6).
NOTE: Take proper precautions to protect the carpeting from engine coolant. Have absorbent toweling readily available to clean up any spills.
9. Remove the bolt (7) that secures the heater tubes to the heater core (8).
10.Disconnect the heater core tubes from the heater core and remove and discard the O-ring seals.
11.Install plugs in, or tape over the opened heater core ports.
12.Carefully pull the heater core out of the HVAC air distribution housing.
13.If required, remove the heater core tubes from the vehicle.
You will not be able to see the entire core, but you will be able to touch it to confirm heat and hopefully see if one if the doors is not properly installed.
Dec 3, 2019 at 5:52 PM
PIPERPUP
  • 10 POSTS
Thank you,
I will work on it a bit tomorrow and see what I can uncover. By the way, rock auto shows a heater core for my jeep 'without" dual zones. That implies there are different cores available. Is that true? If so, could they have put the wrong one in?
Thank you again. I will let you know what I find.
Jim
Dec 3, 2019 at 7:14 PM
The core would be the same regardless. Let me know what you find. This has me really interested. LOL
Dec 3, 2019 at 7:34 PM
PIPERPUP
  • 10 POSTS
Well, I have enough of the dash apart to see the end of the core but that's about it. I did find the occasional coolant smell. The connection to the pipes is not flush at both ends. Slight drip at the bottom. Trying to upload pictures but i may need to go to my laptop to do it.
Dec 7, 2019 at 1:17 PM
PIPERPUP
  • 10 POSTS
I tightened up the fitting and stopped the leak. Ran the car and both the inlet and outlet pipes at the core are hot. The end of the core is hot, but perhaps not as hot as the pipes.
Opening and closing the blend door makes a very minor change in temperature, but not nearly what you would call hot. Keep in mind the car is in a heated garage (70 degrees) as I am doing this.
My thoughts:
1. Air trapped in the core (what genius put the return line on the bottom?)
2. Partially blocked core (minor temp change moving the blend door at 70 degrees ambient air. I doubt you would feel anything with negative 20 degree air entering the system)
Open to any other thoughts before performing surgery on the jeep!
Jim
Dec 7, 2019 at 2:49 PM
I agree. What a design. If you suspect there could be an air block, I would try to open the return where it attaches to the heater hose and see if you can get any air from it. But I have to be honest. It's hard to believe air would still be in there after all this time. Are you getting normal air flow? It just doesn't make sense.
Dec 7, 2019 at 9:00 PM
PIPERPUP
  • 10 POSTS
Yes, normal air flow from what I can tell. I do not like the idea of throwing parts at a problem, particularly a part that is going to be a pain to change, but I am leaning toward pulling the core.
Running out of ideas but I refuse to let this thing beat me!
Dec 7, 2019 at 9:42 PM
PIPERPUP
  • 10 POSTS
Heat!
I don't understand why it works this way when it wouldn't work the factory way or the way the Dodge mechanic told me to plumb it, but I will take it none the less.
Plumbing is now set up like a Commander without the rear heat option. Engine outlet to front core inlet, front core outlet to engine inlet. I don't have any idea what changed as I had hot pipes, inlet and outlet, the way it was plumbed. Regardless, this is how it is staying for as long as I own the Jeep.
Thank you for the input!
Jim
Dec 8, 2019 at 10:54 AM
Wow. One never knows what to expect. So if I understand, you switched the inlet and outlet? Honestly, in my mind I can't understand what difference that made. LOL
Regardless, if it's working, that's great news.
Dec 8, 2019 at 7:55 PM
PIPERPUP
  • 10 POSTS
Update:
So I had some heat when it was 20 degrees or warmer out. At 20 below zero I only had heat for about 1 minute. Googling suggested a partially blocked heater core that could not keep up with demand. So I ordered an OEM heater core and installed it. 27 below zero yesterday and it was so hot on max that I could actually turn it down!
Curiosity was killing me so I opened up the aftermarket core I paid a large sum of money to have installed two years ago. I discovered the blockage was by design. Every tube had the plastic rods in them. I do not know if these exist in the OEM core or not but since it works great now I would doubt it. Sure is nice to have heat!
Jan 4, 2020 at 9:10 AM
I never had one apart. That looks more like pasta. Was that in every tube?
Jan 4, 2020 at 6:33 PM
PIPERPUP
  • 10 POSTS
Yes, every tube. They had to reduce flow significantly.
Jan 4, 2020 at 6:53 PM
Wow! I agree. Regardless, I'm glad you got it fixed and have heat again. There is no way I could handle those temperatures. LOL It's 31°F here and I hate it. LOL
Take care, keep warm, and let us know if you have questions in the future.
Jan 4, 2020 at 11:35 PM
BRITTANYH
While sitting idle there is no heat blowing in the vehicle just cold air. While driving down the road it will blow heat. What could be the issue?
Dec 14, 2020 at 4:03 PM (Merged)
Good afternoon,
It sounds like the heater core is clogged.
I would remove the hoses at the firewall and use a garden hose to flush the core. run it on both sides until you get a good even flow from both sides.
Beyond that, you may need to replace the heater core.
https://www.2carpros.com/articles/replace-heater-core
DON WYZENSKI
  • 5 POSTS
Climate control only changes temperature on left side of vehicle.
The vehicle has a duel climate system. Therefore, there are two blend air doors which determine interior temps. It sounds like one isn't functioning properly. The bad news is they are under the dash of the vehicle and not easy to get to.
DON WYZENSKI
  • 5 POSTS
thank you , that is what my brother thought,
STEVE W.
  • 15,113 POSTS
That one isn't that bad to get to, you need to remove the glove box, the lower isolator panel and then you can get to the actuator inside the glove box opening to the left side.
2CP-ARCHIVES
  • 4,540 POSTS
the heater in my jeep commander only blows cool air, it does not get hot?
Dec 14, 2020 at 4:04 PM (Merged)
check out this guide
