Front heater not working properly
2004 CHRYSLER PACIFICA
20,000 MILES
GRAMCRACKER
There is no air coming out of the front vents or when i push the defrost button. but there is air coming out of the rear vents, but only will blow no heat comes out of the rear vents. my boy friend went to work with the heat working but when he got off no air come out of the front vents.
Feb 10, 2019 at 10:48 AM
SCGRANTURISMO
  • 4,897 POSTS
This could be a problem with your blower motor. I have included a couple of guides down below for you to go through that should help you run down the problem. Go through them and let us know what you find out. We can help with any other questions that you may have.
https://www.2carpros.com/articles/low-or-no-air-flow-from-vents
https://www.2carpros.com/articles/air-vents-stay-in-the-defrost-position
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
Thanks,
Alex
2CarPros
Feb 10, 2019 at 3:49 PM
