Front end problems
1996 FORD EXPLORER
200,000 MILES • 4.0L • V6 • 2WD • AUTOMATIC
A. BENTON
Car really feels loose while driving and wonders left to right really bad sorta feels like a wheel is so loose it's about to fall off. I've replaced the lower ball joints, upper control arms, wheel bearings, outer tie rod ends and sway bar end links all within the past year or so but it feels worse now then ever. also its started popping when I turn to the right under the front end and the car sits leaning towards the drivers side when standing in front of the car but looks like the drivers side tire has no weight on it.
Jul 30, 2019 at 12:49 PM
Have you done lower control arms? it sounds like the bushing are worn out. here is a guide to help us fix the problem:
https://www.2carpros.com/articles/popping-noise
Can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response.
Jul 31, 2019 at 12:53 PM
