I have a front driver's side noise on the vehicle listed above EXT LT. The best way to describe the noise is like a whump, whump. It does it when accelerating and decelerating. I thought maybe a warped rotor or bad caliper but had rotor and caliper checked but was fine and replaced pads. Pads had even wear on them. Just put in a new rack and pinion, power steering pump, lines, and outer tie rod ends. Also had an alignment done. New sway bar links and lower ball joints. Checked wheel hubs for play and nothing. I just got done putting in new CV axles and upper ball joints. Any help would be greatly appreciated. I'm getting ready to watch videos on differential. Don't now what else there is after that. Don't know what else to do. Please help?
Nov 21, 2022 at 10:30 AM
