Front end metallic rattling over small bumps?
2014 BUICK LA CROSSE
34,000 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
CARQUESTION321
When I go over "small" bumps, I hear a metallic rattling from the front right (with window open). Kinda sounds like gravel spinning in a hubcap. It started doing this at 10,000-miles and is now louder.
In the attached video you can hear it from 1-second to 10-seconds (above the road noise). Right at 14-seconds is when I go under an overpass and it's louder.
Sep 17, 2024 at 4:35 AM
Does this car have only 34,000 on it? Also, did you have the brake done on the front recently? If so, stop driving the car because it sounds like the front brake caliper is loose. I would raise the car up and remove the front wheel for inspections, please use the guides below.
and
https://www.2carpros.com/articles/wheel-removal-and-re-installation
Thanks for the video, it helps. Here is what to look for when inspecting. Check out the images (below). Please upload pictures or videos in your response of any problems so we can see what to help you with.
Sep 17, 2024 at 10:08 AM
CARPROSQUESTION
  • 5 POSTS
Yes, 34,000 miles. No brake work done. I forwarded your reply to the Chevrolet service dept. where my car is at (they are struggling with it).
Please send me a link so I can make a donation.
Sep 17, 2024 at 10:40 AM
Okay, it should be obvious what the problem is, please let me know, I am interested.
https://gofund.me/c7d318ad
Thank you!
Sep 17, 2024 at 3:27 PM
CARPROSQUESTION
  • 5 POSTS
The metallic rattling was the front disc brake backing plate. It was tightened so no more noise.
Sep 20, 2024 at 6:47 AM
Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
Sep 20, 2024 at 10:25 AM
