Car makes noise that matches the shake. I put front up on jack stands. Started put in gear. One side quiet and other bounces up and down. The quiet side doesn't spin unless I help it. There is no play in the wheels in up and down or side to side. Tie rods are less than a year. I don't know if wheel bearings can be bad without showing signs of slop or maybe an axel bearing. Tires are also only a month old same before and after. There is some play in the axel shafts at transmission entrance. Any thoughts on where to start would be great. thanks
Oct 13, 2021 at 8:12 AM
