Have you performed a suspension and steering systems inspection? Has the alignment been checked? If so, what was found?
You are describing something that is shifting between acceleration and braking. The more common causes of directional instability are a worn tie rod end and a sloppy control arm bushing. Control arm bushings used to last the life of the car, but for the past couple of decades they have been made from softer rubber so they fail quite often now. They can usually be identified by poking at them with a pry bar, but the movement needed to cause steering wander can be too small to see by eye. Then it will show up as wildly-changing numbers on the alignment computer.
The less-common causes of steering wander include excessive total toe-out on the front wheels, and incorrect toe and/or camber caused by sagged right height. Restoring ride height with new springs can correct multiple symptoms.
A brake pull must be considered too, but do not spend a lot of time on that until all other causes have been exhausted. Most front-wheel-drive cars use a split-diagonal brake hydraulic system so if one half springs a leak, you will still have one working front brake. Years ago with only one front brake working, the steering wheel would get torn out of your hands when applying the brakes. Today, "scrub radius" has been modified to the point that at most, all you will see is a tiny wiggle from the steering wheel. That also means you are less likely to notice a pull caused by a sticking brake. Additionally, you described the direction of steering as varying from driving over road surface variables, not just when braking. That points more to worn parts and mis-alignment.
Mar 28, 2018 at 11:48 AM
