Front end goes to vibrating?
2003 CHEVROLET SILVERADO
330,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
CARLA WHEELER
  • 6 POSTS
If i get up to 55 MPH or faster my truck goes vibrating (not really bad). I have new tires and had it aligned, I've also checked the wheel and there's no play in it. The drivers side sits a little lower than the passenger side it's not bad, but I can tell it is lower.
Jul 13, 2025 at 7:47 PM
MECHTRIX
  • 382 POSTS
Heres a few things to check:
Wheel not balanced super important will make it wobble at higher speeds
Also, a broken or worn out or loose shock
Since it seems to be drooping on that side and you've checked just about everything else. good luck hope this helps.
Jul 13, 2025 at 10:30 PM
If I can add here I have seem the lower ball joints wear and cause the front end wobble. Also, check the upper ball joints as well.
Jul 14, 2025 at 1:17 PM
