Front end
2011 CHEVROLET MALIBU
120,000 MILES • 0.5L • 4 CYL • FWD • AUTOMATIC
NAILMAN19
When I apply the brakes the front end shakes the left side more then the right. Tried new brakes, routers and hub, none of those item helped. It only does it when braking.
Jul 9, 2017 at 5:32 AM
WRENCHTECH
  • 20,761 POSTS
If it only does it when braking, then the problem is definitely in the brake system somewhere. It needs to be examined closely, possibly using a dial indicator to measure the rotor runout.
This continuous problem would also have led to more wear and tear on the steering components on that side which will exaggerate the symptoms.
Jul 9, 2017 at 7:27 AM
NAILMAN19
So I can replace the rotors and calibers and should take care of it.
Jul 10, 2017 at 5:26 AM
WRENCHTECH
  • 20,761 POSTS
You said you already replaced them.
Jul 10, 2017 at 5:32 AM
