More than likely this is a seal that is related to or close to the belt because if you have oil all over this area it is getting flung all over as the belt spins.
The most likely cause of this is the power steering pump but the way to figure it out is to clean the entire area with a spray cleaner and then start the engine again and see where it is coming from. If it is what I suspect, you will want to wear safety glasses because it can get in your eyes.
Let me know if you have questions about this and we can go from there. Also, once you figure out which it is, let me know and I can help with repairs.
Thanks
Sep 6, 2019 at 6:35 PM
