My 1994 Ranger is leaking brake fluid from the driver side rear wheel. I just replaced the master cylinder (my bad diagnosis) and after I did so was when this first occurred. Previously the truck had been parked for several months and I'd decided to drive it only to discover it had no brakes. At that time I checked the brake fluid level, found it to be normal and decided I needed a master cylinder.
I've never had to work on the rear brakes of a vehicle. These are drum brakes and when I looked, the hose that goes into the drum seems very loose, but not in a way that would suggest I could tighten it. Fluid is literally puddling up around the tire. What's gone wrong (most likely)?
Apr 14, 2021 at 10:41 AM
(Merged)
