Hi, I owned the car for only a couple months. My brakes completely locked up (at least in the front) when driving at 45 MPH. I had to get all new pads, rotors, calipers, and hoses. The problem remained. As I'm driving after about 10 minutes, they slowly start to lock up again. I replaced the master cylinder and am having the same issue. I looked to see if I could adjust the push rod and to me it doesn't seem adjustable. When I remove the vacuum hose from the booster it does release the brakes and I can drive again until it starts happening after another 10min then I repeat the process and it releases the brakes again. I'm not sure if I need a new booster (which I can't find online) or if there's another issue going on. Any suggestions?
Aug 15, 2022 at 10:28 AM
