Front Brake rotors
2011 TOYOTA COROLLA
158,000 MILES • 4 CYL • 2WD • AUTOMATIC
UAHDVWJA
  • 7 POSTS
I need to replace my front brake rotors, but they wont come off for some reason. It seems like it is welded to the axle or there is something else holding it on. I have put lubricant on it and hit it a couple times but still will not come off.
Sep 17, 2016 at 8:04 PM
CJ MEDEVAC
  • 11,004 POSTS
Is there one screw in-between two of the lug nut stud holes?
Maybe there is some rust camouflaging the screw?
Keep us posted
The Medic
Sep 17, 2016 at 8:13 PM
UAHDVWJA
  • 7 POSTS
No, I already checked that but no screws there.
Sep 17, 2016 at 8:14 PM
CJ MEDEVAC
  • 11,004 POSTS
Stupid question
But I must ask it.
You did remove the calipers?
The Medic
Sep 17, 2016 at 8:17 PM
UAHDVWJA
  • 7 POSTS
Also, does the nut in the middle of the spindle hold the rotor on?
UAHDVWJA
  • 7 POSTS
Yes calipers off.
Sep 17, 2016 at 8:18 PM
AL514
  • 5,465 POSTS
hit the rotor real hard with a big hammer, i have had to really put some power into hitting these things to get them off, considering you have some mileage on this car, rust will really hold them on. Just do not hit anything else or yourself. And yes double check for that screw. The Honda's always seem to have those screws. There also may be holes between the lug studs where you can put a bolt in and it will pop the rotor off. Spray the rotor with some PB blaster or liquid wrench first to eat some of the rust away. Hope this helps.
Sep 17, 2016 at 8:26 PM
UAHDVWJA
  • 7 POSTS
Alright, I changed the brake pads and everything is good for now. The rotors are not that bad for right now so I am just going leave them go. I just do not want to beat it too hard to where it breaks something. Thanks for the help.
Sep 17, 2016 at 8:33 PM
AL514
  • 5,465 POSTS
oh trust me, i have had to really smash them to get them off, but if you have not done it before or seen it done, then I guess go with your new pads. you wont break anything as long as you only hit the rotor.
Sep 17, 2016 at 8:36 PM
CJ MEDEVAC
  • 11,004 POSTS
I usually do not mess with these kind of vehicles.
I have seen these holes in the rotor before, thought they were for screws
I found this information for you in "Prodemand"
I do not know how to "line up" these marks, but I feel sure this will ease your pain when we do figger it out.
I will message another guy on here should AL514 not know.
See the Prodemand info below.
Keep us posted
The Medic
CJ MEDEVAC
  • 11,004 POSTS
Picture got lost.
trying again.
The Medic
Sep 17, 2016 at 8:37 PM
UAHDVWJA
  • 7 POSTS
When I do get to it, if I put two screws in the holes and tighten them. Will the rotor come off more easily or will it tighten it down more? There is nothing to screw into behind the rotor, the rotor is the only thing containing threads.
Sep 17, 2016 at 8:44 PM
AL514
  • 5,465 POSTS
nothing to line up, just put the screws in the rotor and tighten them in evenly. Side to side, but spraying them with something to break the rust up will help greatly. Let it soak then try the screw holes or smash it with a huge hammer hard, like you hate the rotor. It will come off.
CJ MEDEVAC
  • 11,004 POSTS
Not Good!
Picture shows the hole in the rotor at 12 o'clock (may not matter/ may be at another position) and the text says
"put match marks on disc and the axle hub, remove disc"
I will try picture again.
it does load and will upsize when clicked on-before I submit it!
The Medic
AL514
  • 5,465 POSTS
Also if the screws do not pop the rotor off, do not force them. they will only strip out and then you will have to smash it off. I would put a link on here, but I do not think we are suppose to.
Sep 17, 2016 at 8:46 PM
UAHDVWJA
  • 7 POSTS
Alright, so basically just smash it until it comes off right?
Sep 17, 2016 at 8:48 PM
CJ MEDEVAC
  • 11,004 POSTS
This is weird!
My pictures/ diagrams posted on a post I answered while ago!
Here is the link.
https://www.2carpros.com/questions/wont-start-9029979
You will see the diagrams at the bottom.
The Medic
Sep 17, 2016 at 8:50 PM
AL514
  • 5,465 POSTS
I have done many of these. Never have I seen any marks to line up. There will be two screw holes. one across from the other in between the lug studs. If you put a 12 mm bolt in here and tighten evenly it will come off. or yes spray it down and smash it.
Sep 17, 2016 at 8:52 PM
AL514
  • 5,465 POSTS
The point of the two holes is to put pressure on the hub behind the rotor, and this forces the rotor off.
Sep 17, 2016 at 8:55 PM
UAHDVWJA
  • 7 POSTS
Alright, that is good to know now. Thank you.
Sep 17, 2016 at 9:04 PM
Good to hear, please use 2CarPros anytime we are here to help.
Best, Ken
Sep 19, 2016 at 9:45 PM
