Front blower quit working
2002 CADILLAC SEVILLE
70,000 MILES • 4.6L • V8 • 2WD
LEANORE HAYES
  • 16 POSTS
Front blower quit working the back blower works.
Apr 24, 2019 at 2:55 PM
Good evening,
I attached a wiring diagram for you to view. Check the fuse I circled for power on both sides.
If that is good, you will need a volt meter or test light to do some tests to see if the blower motor or the resistor is the issue.
Apr 24, 2019 at 3:50 PM
LEANORE HAYES
  • 16 POSTS
We checked the fuses out already and they are good. so we will test the resistor and blower motor next. Thanks
Apr 24, 2019 at 5:47 PM
You are welcome.
Always glad to help.
Apr 24, 2019 at 6:18 PM
LEANORE HAYES
  • 16 POSTS
When replacing the blower motor noticed the plug to the motor was burned. what needs to be replaced?
Jun 12, 2019 at 3:55 PM (Merged)
STEVE W.
  • 15,113 POSTS
Welcome back to 2CarPros. As you found the connector burnt I would replace it. You can usually find replacement pigtail connectors at parts stores or the dealer. The burnt area was most likely caused by the blower motor slowly failing. That increases the resistance which increases the current required to make the motor operate. That in turn causes heat which makes the connectors lose spring tension, that causes more resistance and the cycle continues until something fails.
