front axle
2002 GMC SIERRA
280,000 MILES • 6.0L • V8 • 4WD • AUTOMATIC
JASONPYZO
  • 87 POSTS
I was wondering on this truck does the right carrier shaft (passenger side) on the front axle come out just like the left side? I just used a dead blow hammer and tapped out the left one but the right is being a little tough. I got the axle assembly on the tailgate so its easy to get to and was wondering if it is okay to bolt a slide hammer to the axle to pull out or is that not recommended or do I have to take the five bolts that hold the axle tube on? I am replacing the axle seals by the way.
Feb 26, 2017 at 10:31 AM
Hey JASON,
I don't think a slide hammer is the way you get those out. I believe there is an internal C clip that allows the shaft to be removed, here is a guide and video to help you get the axle out, and the carrier shaft out.
https://www.2carpros.com/articles/rear-axle-seal-replacement
and
https://www.2carpros.com/articles/replace-cv-axle
Please let us know happens so it will help others.
Best, Ken
Feb 28, 2017 at 11:29 AM
