Front and Rear Brakes?
2018 BMW 330
103,000 MILES • 2.0L • 4 CYL • AUTOMATIC
TALONLUVSWIFI
  • 35 POSTS
Hi, I'm trying to do front and rear brakes on the vehicle listed above 330e hybrid. My mk808 Autel scanner can't retract the parking brake and I didn't see a motor on the caliper that I could remove to manually retract the e brake, thus I'm stuck. Please let me know what caliper piston compressor tools I need along with how to safely retract the e brake without damaging the caliper.
Mar 27, 2025 at 9:17 PM
This car has parking brake shoes, so there is no parking brake to deal with when doing the rear brake pads. Just compress the caliper normally, I would remove the brake master cap to be safe and put shop towels around it so if brake fluid overflows it will be caught. Let us know how it goes.
Mar 28, 2025 at 10:38 AM
STEVE W.
  • 15,113 POSTS
The park brake on them is a drum system mounted under the rear rotors. No special tools needed for either end. Just be careful to route the wear sensor wiring the correct way.
Mar 28, 2025 at 10:41 AM
TALON LUVS WIFI
  • 15 POSTS
Just to be sure because it has an electric parking button on the center console. You're sure that compressing the caliper piston won't damage the caliper like other electric parking brake motors?
Mar 28, 2025 at 11:37 AM
TALON LUVS WIFI
  • 15 POSTS
Mar 28, 2025 at 11:41 AM
TALON LUVS WIFI
  • 15 POSTS
Also, can I use a brake pad to compress the piston or do i need a special compression tool with an indent on it or something?
Mar 28, 2025 at 11:43 AM
TALON LUVS WIFI
  • 15 POSTS
This is for an electric parking brake system, right? The car has the EPB button on the center console so I'm nervous about compressing the piston.
Mar 28, 2025 at 11:58 AM
STEVE W.
  • 15,113 POSTS
Okay, if it has the EPB button then either the service info is wrong, or you have a unique car. Could you post your VIN please. 2019 they went to the electronic park brake caliper that looks like the attached, those cannot be turned back by removing the motor though, you have to use a scan tool to put them in workshop mode. I suppose you could have a very late 2018 build that has the newer system. The VIN might help with that.
Mar 28, 2025 at 12:45 PM
TALON LUVS WIFI
  • 15 POSTS
wba8e1c57ja180054
Mar 28, 2025 at 1:03 PM
TALON LUVS WIFI
  • 15 POSTS
I called BMW and gave them the VIN. They were saying it doesn't have the electronic parking brake system. That it's cable actuated.
Mar 28, 2025 at 1:05 PM
STEVE W.
  • 15,113 POSTS
Looking at the VIN here shows the same. Hat style park brake with a set of shoes under the rotor actuated by a lever inside the car. As such you shouldn't need anything special, just a way to compress the pistons, basically this same process on both ends.
If you want to take a picture of the console and that button and post it, we might be able to tell what it is. Being you have cable actuated parking brakes it's possible that someone added one of the powered units like GM used to replace the lever.
Mar 28, 2025 at 6:04 PM
