The air vents stopped blowing a few days after a small piece of plastic about the size of a dime in the shape of a triangle fell in it.
Would that cause the vents to stop blowing?
I also spilled coffee on my dash about a year ago. The controls stopped showing on the display but continued to work, I just have no way to tell the temperature because the display went out.
I checked the fuses, everything is fine there. And I purchased a new blower motor and installed it and it still doesn’t blow.
Does anyone have any suggestions or advice?
I have so many miles on the truck I didn’t care to replace the dash controls unless necessary as I can’t find the part for under $250.00. Right now I just need it to blow. The back works fine. I found out that the piece that fell in most likely did no damage because the doors open and switch directions of the air. The problem I m having is that even with replacing the blower motor and checking fuses the blower motor still isn t blowing.
Any suggestions?
Any suggestions?
Mar 4, 2021 at 7:30 PM
