Front AC blows hot air
2004 FORD EXPEDITION
170,000 MILES • 5.6L • 5 CYL • 2WD • AUTOMATIC
MICHAEL ROBLES
When I turn on AC, it only blows hot air, rear blows cold. Could it be the front temperature blend door actuator? If so? What type would fit?
Difference between HVAC heater blend door actuator? HVAC air door actuator?
Nov 29, 2018 at 10:29 AM
Good afternoon,
They are the same. it is called a blend door actuator.
Yes, it sounds like it may be the issue.
Does it blow hot from both sides? Does it have dual control?
Nov 29, 2018 at 1:49 PM
BMDOUBLE
  • 1,139 POSTS
The main issue with the actuator is that the teeth on the plastic gear break. There is a person on eBay that sells just the gear by itself the last I heard. This would save quite a bit of money. Just a heads up.
Nov 29, 2018 at 5:09 PM
