The top front vents will not blow but the defrost works fine and so does the lower vents the back works amazingly, just the front ones. It's going to be getting cold soon I could feel a very little bit of air coming through the vents but I tried disconnecting the HVAC fuses and all that and the battery but still nothing. I feel like it might be the actuator but I'm not sure how to check that. I'm not trying to take apart my car so much. so is there a way to a manually open the vents? I saw on YouTube that there is but it's a pain in the neck. the guy made it look easy though. is there any other way I can manually open the vents? I'd rather have him stuck open rather than closed. I would really appreciate it if you could help me.
Oct 25, 2020 at 7:21 PM
