I had a slight misfire sometimes while idling so I decided to check the plugs and the PCV valve since I read on some forums that the PCV hose was known for getting plugged. Once I was done with the plugs and put the coils back on I could hear a clicking noise coming from one of the coils randomly every couple minutes. Me being the genius that I am decided to put my multi-meter to the plug and ground to the engine block and I believe I may have shorted out the computer. I have an obd2 3100i scanner and it now shows most of the car's components are in the red when they were all green before and the car runs way worse. I didn’t even take it out of the garage. Do I need a new PCM? I messed up and now I need help please!!
Feb 17, 2020 at 2:10 PM
