Freon
2000 CHEVROLET CAVALIER
139,000 MILES • 4 CYL • AUTOMATIC
JAMES WARREN
where is location of low pressure port to add Freon?
Jul 31, 2017 at 1:45 PM
STEVE W.
  • 15,113 POSTS
Are you sure it needs 134A? How did you test it? If it is empty you will need to use a vacuum pump to pull the moisture out of the system and test for leaks.
There are two ports. The common "hose and can" combo kits will only fit the low pressure port which is the smaller port.
Jul 31, 2017 at 2:40 PM
