Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Chevrolet
Cavalier
Climate Control
Air Conditioner
Charge Port
Location
Freon
2000 CHEVROLET CAVALIER
139,000 MILES • 4 CYL • AUTOMATIC
JAMES WARREN
MEMBER
1 POST
FOLLOW
where is location of low pressure port to add Freon?
Jul 31, 2017 at 1:45 PM
STEVE W.
CERTIFIED EXPERT
Are you sure it needs 134A? How did you test it? If it is empty you will need to use a vacuum pump to pull the moisture out of the system and test for leaks.
There are two ports. The common "hose and can" combo kits will only fit the low pressure port which is the smaller port.
Jul 31, 2017 at 2:40 PM
