freeze plugs
1994 FORD EXPLORER
155 MILES
BRANDON 209 ROGERS
my car is leaking coolant in its not coming from one of the hoses or the water pump could it be a freeze plus or is it th water pump
Apr 29, 2013 at 9:45 AM
CARADIODOC
  • 34,306 POSTS
You may find this hard to believe, but we can't see it over a computer. The heater core could be leaking. You'd see the puddle to the right of and behind the right front tire. A core plug could be corroded. Radiator could be corroded.
If you can't tell where the coolant is leaking from, you can add a small bottle of dye to it. Drive a few miles long enough to get the engine warmed up, then search with a black light. The dye will show up as a bright yellow stain that you can follow back to the source.
Apr 29, 2013 at 12:01 PM
