Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Dodge
Dakota
Engine
Block
Freeze Plug
Replace/Remove
Freeze plug replacement
1998 DODGE DAKOTA
150,000 MILES • 2.9L • 6 CYL • 2WD • AUTOMATIC
RBARTSR
MEMBER
1 POST
FOLLOW
Need to replace both front freeze plugs on both sides. Do I need to lift the engine?
Aug 17, 2018 at 9:36 AM
CERTIFIED EXPERT
Good afternoon.
Yes, it would make it a lot easier for access if you lifted it off the motor mounts.
I would suggest doing all of them if you can. If one or two has failed the others are close from behind. They rot from the inside out.
Aug 17, 2018 at 3:55 PM
