Please upload a short video in your response of the problem, so I can see what's going on and I will help you further if needed. Ken
Apr 7, 2026 at 10:48 AM
WGREGQUINN
MEMBER
I have found reason i was confused. Thein line 6cyl engine block in this is a DA26 remanufactured and the freeze plugs & locations are totally different then the AMC258 OEM
Image (Click to enlarge)
Apr 8, 2026 at 9:19 AM
CERTIFIED EXPERT
Yep, the freeze plugs are on the left side of the block, also please check the plugs on the cylinder head as well. Can you upload an image of the leak?
