if it is between engine and trans pull trans to get to it.
Jan 27, 2016 at 9:26 AM
HMAC300
CERTIFIED EXPERT
Or if on side by firewall you may be able to reach being under it but it's not going to be easy
CRAKKKER
MEMBER
How do I install the freeze plug
Jan 27, 2016 at 9:46 AM
HMAC300
CERTIFIED EXPERT
if the old one is not out and bad, punch a large screwdriver through it and pry it out. to install a new one use locktite around new plug then tap in either with a socket that will fit inside or a small hammer around edges.
