Freeze/expansion plug location
2008 LINCOLN MKX
175,000 MILES • V6 • 2WD • AUTOMATIC
AMBER BENNETT
I am having a coolant leak under the car. Appears to be where the transmission and motor meet. Is there a freeze/expansion plug located there? I have searched all over the internet and can not locate a diagram.
Apr 7, 2019 at 4:14 PM
Good afternoon,
There are two core plugs at the back of the engine. The transmission has to be removed to gain access.
These rarely fail, Usually, it is a hose or gasket that has failed.
Did you pressure test the system?
https://www.2carpros.com/articles/radiator-pressure-test
Apr 7, 2019 at 4:21 PM
