Fourth Gear Replacement?
2008 CHEVROLET COBALT
136,878 MILES • 2.2L • 4 CYL • 2WD • MANUAL
AZDANNO04
  • 343 POSTS
I am replacing my slave cylinder and figured I check to see if I needed to replace the fourth gear since I haven’t been to get into fourth gear. It just keeps grinding but after three or four times if I get it a certain angle it will catch, but I know one night I was trying to get it in fourth gear when I heard a loud noise and it felt like I may have chipped a tooth or more on that gear. If you can help me how to get to the fourth gear if that's what I need to replace or I was told the synchro something?
May 6, 2023 at 6:50 AM
Sure, here is a video that shows how to get the transmission out and I have included the transmission rebuild diagrams in the images below:
https://youtu.be/6N6b5F2ChyE
Check out the images (below). Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
May 6, 2023 at 12:14 PM
AZDANNO04
  • 343 POSTS
When I loosened the axle out on the driver’s side I captured over four quarts of transmission fluid.
May 13, 2023 at 4:56 PM
Good job, you don't want that to run out all over the floor.
May 15, 2023 at 9:47 AM
AZDANNO04
  • 343 POSTS
Is there any other steps to proceed to the gears I was told that every gear has a syncro? Right now I am at the flywheel.
May 15, 2023 at 12:29 PM
AZDANNO04
  • 343 POSTS
Question about the quantity of fluid in the transmission? I thought it took less than 2quarts to top off the fluid. I just captured over 4 quarts when I removed the driver side axle.
May 15, 2023 at 12:54 PM
Fluid Types
MANUAL TRANSMISSION FLUID
GM Part No. U.S. 88861800, in Canada 88861801
Capacities
MANUAL TRANSAXLE
Complete Drain and Refill .................... 1.7 quarts (1.6 liters)
NOTE: All capacities are approximate. When adding, be sure to fill to the approximate level. Recheck fluid level after filling.
May 16, 2023 at 12:15 PM
