Four-wheel drive not working
2008 JEEP PATRIOT
194,020 MILES
LJC5050
The drive shaft going from transfer case to rear differential is not spinning even with the four-wheel drive engaged. Knowing that the transmission fluid is shared with the transfer case I checked that, and it is full. I had rebuilt the rear differential and that checks out to be good still. I checked all of the wiring that has to do with all the four-wheel drive including the ABS wheel sensors and those are all good. I checked any fuses as well as relay fuses and those are all good as well. I'm really stumped on this one as I already know quite a bit about Patriots.
Feb 8, 2022 at 7:14 PM
This could be a few things. The AWD module may have issues, there could be a low voltage signal from the switch, a bad switch, or an issue in the can-bus.
CAN stands for controller area network. Basically, all the different modules are tied together via a few wires. If you scan the CAN, it should retrieve codes regardless of the module storing it. Here is a link showing how it's done:
https://www.2carpros.com/articles/can-scan-controller-area-network-easy
This is where I recommend starting. Otherwise, we will need to start checking voltages, resistance, connectors, and so on. If we have a code, it will point us in the right direction.
Let me know your thoughts. If you have already retrieved a code, let me know what it is.
Feb 9, 2022 at 4:36 PM
