The drive shaft going from transfer case to rear differential is not spinning even with the four-wheel drive engaged. Knowing that the transmission fluid is shared with the transfer case I checked that, and it is full. I had rebuilt the rear differential and that checks out to be good still. I checked all of the wiring that has to do with all the four-wheel drive including the ABS wheel sensors and those are all good. I checked any fuses as well as relay fuses and those are all good as well. I'm really stumped on this one as I already know quite a bit about Patriots.
Feb 8, 2022 at 7:14 PM
