will ignition module prenvent car from starting
FORD WINDSTAR
DDENTLY52
car turns over but doesn't start, replace distrubutor cap rotor ignition coil and ignition wires still nothing, start turns engine get sparks from plugs but nothing no start? please help!!
Apr 5, 2006 at 1:54 PM
SPONGER
  • 22 POSTS
A bad ignition control module will keep your car from starting. You may want to do a test on the ICM before you go buy one. I have a 1994 Ford Explorer and the ICM for my truck was a little over 150 dollars. Also, try checking your other relays and sensors... namely the crankshaft position sensor.
Apr 5, 2006 at 2:18 PM
PEPPERMRJ
  • 1,158 POSTS
Only on cars that have one. What year, make, model, and mileage?
Sponger is giving you good advice. Follow it and let us know.
Good luck. :)
Apr 5, 2006 at 5:51 PM
