Vibration at all speeds till 65 mph
1965 FORD WINDSTAR
My 2003 Ford Windstar LX van has 90000 miles on it. It has a 3.8 l engine. For the past two weeks, it started shuddering and shaking at low speeds till 45-50 mph. The steering wheel also vibrated along with the van. Now this happens till 65-75 kts. The speed is not fixed. The vibration is felt most severely at low speeds of 15-20 mph on the steering wheel. At high speeds, this shuddeirng of steering wheel reduces significantly.
The tires need replacement. One of the tires was not good and I had replaced it with a similar used tire. I am not sure if the shaking and vibration is only because of alignment/balancing/ worn out tires or there is another problem? :D :D
Aug 6, 2007 at 11:10 PM
SERVICE WRITER
  • 9,123 POSTS
Sounds like it may be a shifted belt in the tire. Regardless this needs to get looked as it sound like a serious saftey issue. Jack each front wheel up for starters and move each whell back and forth with your hands on the 3 and 9 o'clock positions and the 12 and 6 o'clock positions. There should be no play at all. Don't put this off.
Aug 7, 2007 at 1:24 PM
