Radiator
FORD WINDSTAR
AGELESS
I have a 1998 Ford Windstar, v6-3.8L, approximately 105,000.
Ive been having the radiator fluid visibly turn black in the reservoir. I flushed the radiator fluid and had it turn again. I took it to the dealer and they said they simply felt it was rust and sediment and they could do a better job using their kit they could get more pressure on it and use a solvent that would help really clean it out. After driving it only a week after getting it back from the dealer, the fluid is turning black again. It does look like rust, not like oil from a head gasket. Would flushing again be advisable or should I look at replacing the radiator? I talked with a couple companies online, some said that radiator was easy to replace, yet a couple said it was a little more difficult. Is this something a novice could do themselves?
Apr 25, 2007 at 3:08 PM
BESTBET777
  • 89 POSTS
Oil in the water will feel slimey or slippery, rust or corrision will feel gritty.
first thing is to fix oil if tthat is the problem, blown head gasket.
If it's gritty flush the system properly.
Apr 26, 2007 at 9:17 PM
