Power lock problem
FORD WINDSTAR
JRC0109
  • 6 POSTS
1995 Ford Windstar mileage 105,000. I have a problem with power locks in my minivan. The doors unlock perfectly whether by a remote control or by pushing any of the buttons inside (driver, passenger Tailgate door), but will not lock from any of them. It's not a problem with the remote as the lights blink and honk sounds when I press the Lock button, but the doors remain unlocked. Pushing any of the Lock buttons inside also produces no result.
Any ideas would be appreciated?
Dec 23, 2006 at 7:14 PM
MATHIASO
  • 1,209 POSTS
In troubleshooting this system, first check both the gauge and the power fuses, next identify what component has failed.
you can either perform a continuity test or use a jumper wire to troubleshoot a single motor problem
Two other problems that can occur with a power door lock system are a failure of the ignition switch contact or failure of the main electronic control relay module
Dec 23, 2006 at 8:04 PM
