Instrument cluster speedometer and tachometer
FORD WINDSTAR
CHAPMAN
Ford Windstar 2000. 3.8L 120,000 miles.
Every summer I get instances when all the dials will go haywire. The speedomete might register 120mph when the actual speed might just be 60mph. The tachometer might go to zero or to maximum and the gas gauge might go to full. After a while they will return to normal, sometimes after a scary 40 miles down the road.
Jun 18, 2007 at 8:47 AM
98RANGERXLT
  • 301 POSTS
Have the battery checked it sounds like the battery
Jun 18, 2007 at 9:43 PM
2CARPRO JACK
  • 11,533 POSTS
HELLO! Came across it twice in that era. the PCM is the voltage regulator on this beast. book says 13.6--14.6 for volt range as i recall. BULL! 14.2 turned out to be the minimum. since this has many clicks on the odometer and only happens in warm weather my first suspicion is plugged rad. fins. even at 60MPH and the A/C on- the PCM can turn the high speed engine cooling fan on. add the dual blower motors inside and you are sucking many amps and dropping voltage at the same time. scroll down to ALL OTHER CARS in the main menu. open it and drop down about 16 posts to the 2003 SABLE STOPS.....i describe how to make a tool to clean those fins. i would start with that approach rather than an alt.
Jun 20, 2007 at 8:12 AM
CHAPMAN
Did a DdieHard express test on the battery. Load volts was 14.04 and No load volts 14.09. Replaced engine coolant which was dirty according to a certified tech. Checked all hoses and the performance of the thermostat. Blew out debris around radiator with ordinary air pressure blower without taking out the fin covers yet. Temperature is not yet in the range where the problem occurs 89*-93* I will watch it a few days before going to the fins cleaning which was estimated to cost$60.00
Jun 21, 2007 at 9:08 AM
