Ford Windstar 2000 not auto shifting to higher gears/speeds
2000 FORD WINDSTAR
MIKEO
Have a Ford Windstar 2000 with 108K miles. Runs in Drive, but would not auto shift gearup to higher speeds (max is about 25) unless I manually shift lower to gear 2, then it only runs as fast as 40. Check engine light also came on. Battery was weak bcos the van has been sitting for a while, but appears to charging back up.
Later checked transmission fluid and added some Mercon V. Runs a little faster in Drive, but soon started flashing O/D light.
After about 2hrs of resting the van, started the van, the O/D light did not come on again even when driving but the speed issue returned - runs in Drive, but would not auto shift gearup to higher speeds, runs as fast as 40 in gear 2. Check engine light still on.
Please advice.
Mar 4, 2006 at 1:09 AM
WRLHAMON
Mikeo- I'm having EXACTLY the same Problem with my 1997 Ford WindStar..(See my Post--Dated Match 21, 2006--Author- wrlhamon) Have you solve your problem? If so. would you be so kind as to tell me what you did? Would be very much APPR!!! Thanks
Mar 23, 2006 at 5:19 AM
