1987 ford laser ghia, 1.6L EFI engine, 230,000 km
hi,
recently my car was not running at all, i found the fault to be the fuel pump, which i replaced, and now it starts and idles.
as soon as i put the throttle in, the rev's go down, and when i let it out it jumps up a thousand or so then back to normal, running pretty badly (spluttering, backfiring etc).
the exhaust has a little white/grey smoke coming out (not alot) and i saw a tiny plume of smoke coming from what looked like the exhaust manifold.
can you help me?
-edit- if you partially clamp the fuel return hose the engine runs alot smoother, could this be something to do with the fuel pressure?
hi,
can you help me?
Jan 28, 2007 at 9:15 PM
