brake fluid
FORD WINDSTAR
MYCIOGIRL
What kind of brake fluid would I need for a 1998 Ford Windstar?
Jul 20, 2006 at 9:45 PM
MIKEYBDMAN
  • 623 POSTS
High Performance DOT3 Brake Fluid Ford Specification ESA-M6C25-A.
For a 1998 Ford Windstar, the recommended brake fluid is DOT 3 brake fluid. This is a glycol-based fluid, which is standard for most vehicles of that era, including Ford models. Here are a few key points to consider:
Check the Owner's Manual: Always refer to the vehicle's owner's manual for the manufacturer's specific recommendations. The manual for your 1998 Ford Windstar should confirm the type of brake fluid needed.
DOT 3 Specifications: DOT 3 brake fluid is suitable for the hydraulic braking system of the Ford Windstar. It has a lower boiling point compared to DOT 4 and DOT 5.1 fluids, but is generally adequate for normal driving conditions.
Compatibility: If you are adding to existing fluid, ensure that the new fluid is compatible with the one already in the system. DOT 3 fluids can usually be mixed with DOT 4, but it's best to stick to the manufacturer's recommendation.
Avoid Contamination: Brake fluid can absorb moisture from the air, which can lower its boiling point and potentially cause brake failure. Therefore, it's important to use fresh fluid from a sealed container and to ensure that the brake fluid reservoir is sealed properly after maintenance.
Jul 21, 2006 at 3:11 PM
