2003 Ford Windstar Leaking Line
2003 FORD WINDSTAR
SDGREATHOUSE
Transmission problem
2003 Ford Windstar 6 cyl Front Wheel Drive Automatic
A metal line, coming off the radiator at a connection, has been spraying transmission fluid on the passenger wheel. Do the metal line connections have O-rings and could this cause my problem?
Apr 22, 2010 at 4:04 AM
Yes, they have o-rings and that could be the problem. If it is leaking badly, have it repaired before you damage the transmission. As far as the fitting, there should be either a C-Clip that is removed that holds the quick connect, or you will need to squeeze the two sides of the quick connect to remove the fitting.
May 12, 2010 at 1:28 PM
