fuel pump relay location
2003 FORD WINDSTAR
SAMMMOORE
What are the causes of the fuel pump not engaging? Installed new fuel pump and it is not engaging. What are the areas that need to be checked? Also check tires and reset appears on the led screen of vehicle.
May 1, 2009 at 8:52 PM
It sounds like the relay is not working here is a guide to help test it and the location of the relay below.
May 1, 2009 at 8:58 PM
REVBUFFETT
2002 Ford Windstar Front Wheel Drive Automatic
where is the fuel pump relay located? and what dose it look like?
Feb 12, 2019 at 4:54 PM (Merged)
It is located in the battery junction box.
https://www.2carpros.com/forum/automotive_pictures/12900_bjb_1.jpg
It should look like this:
https://www.2carpros.com/forum/automotive_pictures/12900_fpr_14.jpg
GZAZUETA
Electrical problem
1996 Ford Windstar 6 cyl Four Wheel Drive Automatic
where is the fuel pump relay located in the ford windstar 1996 3.8.
BLUELIGHTNIN6
  • 16,542 POSTS
The fuel pump relay is located in the constant control relay module, under the battery rack on the left side of the engine..
Thanks for using 2CarPros.com!
ROUGHECK8806
My Windstar sat for almost a year with transmission trouble. When we fixed the tanny we couldn't get the motor to run because it keeps blowing the fuel relay fuse. I have checked the filter,sensors, and the wiring harness and can't see a problem other than the pump. I have not dropped the tank to check that.
BAD74CHARGER
  • 8 POSTS
I would change the pump if everything else looks good..
428COBRA
Engine Mechanical problem
1996 Ford Windstar Two Wheel Drive Manual
where is it
DAVE H
  • 13,384 POSTS
FUEL PUMP
Removal
Release fuel pressure. See FUEL SYSTEM PRESSURE RELEASE under FUEL SYSTEM. Remove fuel tank. Using fuel tank lock ring wrench, carefully rotate lock ring counterclockwise to release pump. Remove fuel pump from tank.
Installation
Wipe seal area of tank clean. Position new "O" ring seal onto pump, using grease to hold it in position. Position fuel pump in tank so fuel return hose is not kinked. Install lock ring. DO NOT overtighten pump lock ring, as it may leak. Install fuel tank.
428COBRA
Electrical problem
1996 Ford Windstar 6 cyl Two Wheel Drive Automatic
i have a 1996 ford windstar where is the fuel punp relay it
JDL
  • 16,098 POSTS
https://www.2carpros.com/forum/automotive_pictures/170934_ford_fuel_pump_relay_1.jpg
The info I looked at was the 3.0L, driverside, under the hood.
2CP-ARCHIVES
  • 4,540 POSTS
where would you locate and replace a fuel relay switch?
very rare failure. what is the issue????
the relay is under the hood.
BERNARD ATKINS
can you please tell me where to find the fuel pump relay, and how to test it?
KLSHIEL
  • 163 POSTS
The relays on the '97 Fords were in the under hood fuse box. The cover should have the position of the fuel pump relay labeled. They always like to put three or four togeather and they all look the same, so the best place to find out which one is the right one if it isn't on the cover is in your owners manual. Two ways you can test it is if you put your hand on it and have some one turn the key from off to run you should hear and feel the relay click. Another way is to take one of the other matching relays from something else and switch them. If your still not sure one way or the other the relay only costs about $10 and it doesn't hurt to have a spare.
Whats wrong with the fuel system is it- you don't hear the fuel pump come on when key at run position. Could be the inertia switch or the pump itself.
Direct battery power to the pink and black wire at the inertia switch-did the fuel pump come on.
